RCU Forums - View Single Post - another BT-32EI question/problem
Old 11-27-2007 | 05:04 PM
khodges
Default RE: another BT-32EI question/problem
ORIGINAL: khodges
I have checked the screen in the carb and it is spotless.
Yeah.
Things I have NOT done:
taken the diaphragm side of the carb apart to see if the diaphragm has a tear or pinhole (How would I find a pinhole without destroying it, and would it run at all if the diaphragm was torn/pinholed?
tried a different spark plug--don't think it's the problem, the couple of times I've gotten good rpms, it was fine
tried a different ignition module (don't have one to try)
Even at 50:1 oil mix, I still get a LOT of black goo out the exhaust. I'm almost inclined to think that this Amsoil Saber is made for a much leaner mix than even 50:1. The bottle says 100:1, but I didn't want to try it that lean until I had the engine running well and broken in. I can't see that the Fuji oil is any better than Amsoil or Klotz and I can't find it anyway.
Any other suggestions, before I have to remove the engine and ship it back?
