RE: Inverted Engine
Engines without float type carbs such as our model engines will run in any position. That's why we can fly inverted all day long. The issue is always tank to carb placement. If you can get the tank located correctly, an inverted engine will run fine, assuming you don't flood it during start. Otherwise you will need a pump for consitent runs.
