ORIGINAL: RU4JESUS2 FALCONGTS
hey D L R thunder tiger cub and the p51 mustang are good planes the best motor is the OS 25 fx and 9x5 prop only thing is move the landing gear forward will nose over alot if you do not . very easy on fuel , on the light side 3.5 pounds if i remember correctly
you can fly slow or fast
do they still make them ???
good luck falcon
Thanks for the info Falcon, about the gear, that is one area that seems problamatic, doesn't seem it will flex real well, more like a hard landing and it will be bent, maybe I'll get a better one I had considered moving it up to the LE of the wing and will do it now for sure. Right or wrong, I'm putting a TT pro36 on it for power, more than enough I'm sure, but I use both hands when I fly and one of them holds the throttle so I'm not worried about a little extra power. Maybe it will hover, ha ha.
Yes, apparently they are still making them, it took a month for my LHS to get it, but the plane and engine both showed up finally. Nice to hear about the P51 as well, maybe next winter!!
Dan
