RCU Forums - View Single Post - Fairings at the wing root
Old 11-27-2007 | 10:09 PM
iron eagel's Avatar
iron eagel
Default RE: Fairings at the wing root
Bruce,
A couple of months ago I slammed a thirty year old TF Mustang into the ground. Not even the motor survived I'm not to sure about what happened, it may have been a high speed stall. Lost control and got into a spin up high, stopped the spin and when I tried to pull up the nose came up and the plane continued down nose high till it hit the ground. Hence my wanting to try something else before I trash another old plane still knocking the rust off.
The main reason for the SE is that I have it and it is designed for more performance than a trainer would be. I have a brand new OS 55AX I plan to put in it so power to weight should not be much of an issue.
I hope to keep the basic flying weight as close to the 4 lb figure as possible so as a sport plane it will still perform, and by varying the wing loading I may be able to see how it reacts with more load.
