RE: gas fuel with glo plug no ignition
Baxy ... you are correct. Plus the cooling effect alcohol has on the mixture helps, and one can design an engine for use with alcohol at a higher compression ratio. Both of these factors also help the power output of an alcohol engine.
AV8TOR
