RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 11-28-2007 | 01:08 AM
  #1860
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
1705493-AndyW -- Try this, I just did it and it worked fine.
At the top of your screen, click on "Edit" then "Select All", then click on "Edit" again, and then click "Copy". Then hit "Start", "Programs", "Accessories", then "Notepad". (I tried it with "Wordpad" and for some reason it wouldn't work)
In the "Notepad" that opens, click at the beginning of the document, then right click, and select "Paste". All the writing that you had copied will be on the document. You can then save it with an appropriate name such as "Gas/Glow Page One" for example.
AV8TOR
