Amt Pegasus HP pipe
Hello guys, just wondering if anybody has had any good performance with aftermarket pipes for the latest AMT Pegasus HP.
My problem is that I have an Avonds F-15(old kit), and the fully ducted setup with the standard pipe is severely limiting the engine.
What I plan to do is to remove all the bypass ducting and use a bifurcated pipe with a bell mouth set up. Does anybody have any actual
experience with this same airframe/turbine combination? What pipe is being used?
Any help would be greatly appreciated.
Thank you, Frankie
