RCU Forums - View Single Post - Ignitions on A123 Cells??
Old 11-28-2007 | 09:51 AM
  #120
Antique's Avatar
Antique
Default RE: Ignitions on A123 Cells??
If you use the diode voltage drop method to run your reciever+servos+ignition be very sure that you use a HIGH current diode. That .7 volt drop is dissapated as heat, calculate the load and size the diode accordingly.
