RE: Hiding the wire
I am a believer of Murphy's law that there will always be some little problems especially with new technology. If it can go wrong then somebody somewhere will give it the chance to go wrong. All I have done is changed the angle of the connector ,i haven't hidden the wire or modified the connector link in any way. Maybe JR will look at mounting the connector parallel to the module instead of at right angles. The range check after the mod is exactly the same as before.
