RCU Forums - View Single Post - Lost my plane!
Old 11-28-2007 | 01:41 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: Lost my plane!
Do you have the capability to test your battery under a current load? Also I have seen where a loose connection in the on/off switch can have the same result. It will be acting just fine and from the vibration of operation the connection is lost and the plane stops responding. Other possibilities include problems inside your receiver or transmitter. My point is once a problem is identified check everything that you are qualified to check thouroughly and have a qualified person check everything else.
