RCU Forums - View Single Post - Sig Smith Miniplane build
Old 11-28-2007 | 02:47 PM
  #146
hardnut
Default RE: Sig Smith Miniplane build
Chrispeace
Thanks for the idea about the plastic book binders ,as i have said before i have covered them with solarfilm but have only flown it twice since then (great british weather and work[&o]) so will try that if mine still doesnt work.
im afraid i can't comment on the problem you are having with your engine as i have used electric in mine ,only thing i can say is if you can hover then you must have loads of power i would try a smaller prop ! (less power/less heat) as this is not a 3d model 30+year old design
rob
