As stated before, this has nothing to do with servo speed. You need to change the amount of throw in your control surfaces. Your plane manual should suggest a low and high throw suggestions. Go with the low throw settings and you'll have a much more controllable, better flying plane. Also, it doesn't take much stick movement to fly a properly setup plane. Small Movements!!!
