RCU Forums - View Single Post - What is Balancing?
Old 11-28-2007 | 05:55 PM
patnchris's Avatar
patnchris
Default RE: What is Balancing?
the other option would be a balancing charger. In effect a balancing charger is many small chargers in one case. In the case of a balance charger you would charge through the balancing tap. The balancing tap has a positive lead from each cell and a common negative lead. Using this method, each section of the balance charger charges a single cell. since Lipo chargers automatically trickle down as the cells charge, all cells will charge to the same value, before the charger signals the pack is fully charged.....Pat
