Beginner
I got started about 6 weeks ago with a Corona. Before that I practiced with FMS to get the stick directions down (other than for that it's not very realistic as far as handling goes).
I've been very happy with the Corona. If you decide on that I'd recommend putting some foam pipe insulation around the tail boom as I bent mine up pretty bad from the blades hitting it on hard landings. The foam really helped.
Good luck!
