Getting ready to start building the Dazzler
ecajberry:
nothing wrong with keeping your dazzler light!!
Build 1/2 in bigger elev & 1 in. bigger rudder, also you may cut a bigger "V" in the ele to allow for more rudder movement.
t the radio comparment hatch needs to be reinforce where the wood srews go & the tip from ramcharger is also good!!.
I personaly like the landing gear system, now a days I donīt bend it however at the beginig I did, It worked fine since nothing has been broken because of it ( it absorbs hard landing hits well)
I have in mine an OS 46fx, 12x4 and it is nose heavy, I have cg at 3 1/4 in. It holds knife edge and arobatics are nice in general however it is not as nice to land as at cg= 3 in.
even if you install a 40 size engine still will be nose heavy, I went throu that already!!
enjoy!!
