RCU Forums - View Single Post - Customizing monokote/ultracote looks (ie painting on/detailing) Hangar 9 Spitfire
Old 11-29-2007 | 06:56 PM
Spitfire13
Default RE: Customizing monokote/ultracote looks (ie painting on/detailing) Hangar 9 Spitfire
Great info guys! So you're saying that Rustoleum is a better candidate than the paints that monokote or ultrakote sell? Also, with the mixing of the paints, are you saying use an airbrush to apply it? If so, does that require a brush and compressor or is there an easier way to get around that? Also, although I will do the clear coat, but will the paint remain on even without it?? Once again, thanks for the help, if this works I plan to convert this thing to a MK V with canons!
