RCU Forums - View Single Post - Flaps or Alierons Which to Y
Old 11-30-2007 | 01:20 PM
-pkh-'s Avatar
-pkh-
Default RE: Flaps or Alierons Which to Y
You can just put the servo arm on the other side of the servo to mechanically reverse it. If the placement for the elevator servos makes this difficult, then it's probably best to use the extra channel there, and then use a Y-harness for the aileron or flaps, since flipping the arm to the other side on those servos is usually quite simple.
