RE: Any GOOD canopies for CX2?
Brett, The boom kit on the CX2 is from Boomtown Hobbies and is the M3 version...I just made it 1/2" shorter and cut away some of the mount to equal the weight gained with the aluminum sleeve used from two antenna packs...Just for bling, & making my heli balance perfect with the battery out...The fins I just painted & clearcoated just for a different look to amuse over...Lol..The antenna is a different diameter for each piece telescoping up, so if you have two antanna packs you'll be able to then have two pieces which are the same and you just find the diameter that fits the most snug as you slide it all on...It looks all like one piece once everything is put together and the two lengths are cut good...I've been keeping my weight of the heli at 227g for now, which is stock weight, but I fly outdoors and prefer my weight at around 232 grams for my preference...Have a good one, Jeff
