ORIGINAL: yodada
One tip that helped me a BUNCH on Dean's connectors. Keep the male and female end connected as you do the soldering. This helps keep the connectors aligned and make for much easier disconnect when you put them into service.
I have always followed the instructions (#3) and have found my connectors come apart without too much force. I have not had to drill or use pliers to disconnect my Deans connectors
