RCU Forums - View Single Post - No Data being read from Weatronics Unit
Old 12-01-2007 | 04:25 AM
mboland's Avatar
mboland
Default No Data being read from Weatronics Unit
I am in the process of setting up the 12/20 Gyro in a new model and all is going well with the RxSetup program. The unit talks to the PC no problems and I have used the software quite a bit to fine tune servo groups, directions, etc.
I had a suspicion that a flap servo was binding and after some tests decided that the data analysis program was the easy answer to indicate servo loads and answer my question.
The Data analysis program does not get any data from the Weatronics unit and I can't see why it wouldn't.
There seems to be no 'Load' button or menu selection so I assumed that it loads the data automatically from the unit if connected.
I have an SD RAM card in the Weatronics unit, is there any special function I have to perform to get it to store data?
Any help in pointing me in the right direction would be appreciated.
PC is Windoze XP Pro in emulation.
