RE: keep the heli low or high?
Matador,
Another thing to consider when landing is the surface you want to land on. If you have problems landing on grass or dirt use a sheet of plywood. 1/2 inch thick or larger should be fine. Thinner plywood has a tendancy to bend and bow over time. A good thick sheet of plywood will give you a hard flat surface to land on. If you're flying a TREX 450 size heli or smaller a 3 ft by 3 foot squar should be a good size. If your flying a larger heli or if you heli is kind of "all over the place" as you're landing it, go with a larger square of plywood. I've seen folks get all fancy with their plywood and paint it up to look like a heli-pad (large circle with a H in the middle).
Hope this helps some.
Ted
