ORIGINAL: babuttila
Hello guys!
I installed the AR6000 into a SJM 400 v2
Here are the connections:
1. BAT port - not connected
2. THR - connected to ESC
3. AILE - connected to Right Servo
4. ELE - connected to rear Servo
5. RUD - connected on gyro im using a ESKY Head lock gyro
6. GER - connected to gyros orange cable
7. AUX - connected to Left Servo
But still it isnt working well!
The servos not working well i pull the stick backwork and nothing happens ???[
I pull it forward its not going forward i cant assemble this with my Dx6 [&o]
CAN ANYONE HELP ME??
Is anything happening at all. If nothing is happening rebind your Radio to your Receiver and try again. You will also need to program the DX6 for your heli it is not plug and play. Download and watch the CCPM [link=http://www.helifreak.com/showthread.php?t=11373]Setuup Videos at Helifreak[/link]. The programming process is shown on a T-Rex but it is basically the same for a Axe CP. You will not have to setup the head but you will have to program your throttle and pitch curves, set the pitch of your mainblades, your cyclic pitch and adjust your gyro.
Good luck and enjoy the new radio!
