RCU Forums - View Single Post - mvvs-58 idle down issue
Old 12-01-2007 | 02:50 PM
Craig 01
Default RE: mvvs-58 idle down issue
Possibly a vacuum / air leak,crank seal ,loose fitting pulse line maybe,or slight restriction in carb idle circuit leaning mixture if idle mix set slightly rich prior are some things to check.
