ORIGINAL: tim220225
Sounds good. I would still face the rods off to square them before you do any drilling or tapping. Also both ends as you will need reference points for your measurements.
Do you mean face off the sides or where the cap joins? Last to be drilled is big end then small end...correct? Thanks Capt,n
