RCU Forums - View Single Post - Need Help Please
Old 12-01-2007 | 03:22 PM
hylandmotorsport
Default RE: Need Help Please
Thanks for the response shizack,
This was my first thought as well, I've checked again and it seems to be correct. In the Spektrum instruction it has a diagram that identifies the servos by name and channel. This was very helpful to me as I'm new to Helicopters.
In their instructions they have listed Ch1 as Throttle and this is going to my ESC. The AR6000 Rx uses descriptions not channels but I think I have it right. The descriptions match up to your descriptions above but not the channel numbers. But then again you have listed the E-Sky Channels but I thought these would have been the same? I bought the ARF kit not the RTF kit so I don't have the E-sky Rx to reference. The E-Sky manual only lists descriptions too.
I've listed what I have connected below and described where the servo is so you can check that I've not misunderstood anything myself:-
(I've listed the Rx description first, the numbers in brackets are the channels according to the Specktrum instructions)
BAT - empty
THR - ESC (1)
AILE - Aileron (servo on left side of swash plate when lookng from behind the Heli) (2)
ELE - Elevator (servo at the front of the swash plate) (3)
RUD - to my Gyro which then goes to my rudder servo (4)
GER - Empty (5)
AUX - Pitch (servo on right side of swash plate when lookng from behind the Heli) (6)
Many thanks again for taking the time to respond to this thread.
Cheers
David
