RCU Forums - View Single Post - GP Super Sportster 40 MKII Build
Old 12-01-2007 | 03:31 PM
jrcaster's Avatar
jrcaster
Default RE: GP Super Sportster 40 MKII Build
Last night after I posted the pics, I went back and added a fillet on every joint with wood glue. When I got up this morning I checked the ribs, The tip rib wasn't square. I had to dig out the wood glue in that rib, and use debonder to loosen the CyA. I ended up breaking the front section of the rib, and broke the tab off. I used medium CyA and kicker to the tab, and I will have to wait till all the debonder evaporates before I can continue. I will give it a couple of hours to be sure.
1. This is the fillets of wood glue
2. broked rib, That is as far as I had to go, the bottom spar joint was square, and so were the LE and TE joints.
ID:	816105   Click image for larger version
