RCU Forums - View Single Post - Freedom 20 Vert. Stab problem?
Old 12-01-2007 | 10:38 PM
buzzard bait
Default RE: Freedom 20 Vert. Stab problem?
It is a weak spot on this plane. Now that it is broken, it must be fixed before you fly it. You'll need to strip away some of the covering material so you can get at the joint, see where it is broken, and glue it. It would be good to strengthen it with some triangle stock at the base of the fin. Don't add big pieces or globs of glue--you don't want to add significant weight back there. Jim
