RCU Forums - View Single Post - Wild Hare Ultimate?
Old 12-02-2007 | 06:05 AM
Tired Old Man
Default RE: Wild Hare Ultimate?
Install the plate across the wing joint, over both holes, in one piece. If you have some small scrap balsa blocks laying around you can make two filler pieces that will fit between the wing and the inside wing mount for a little extra support to prevent the wing bolts from getting over tightened. Drill them for the wing bolts before adding them to the inside wing mount. It's not needed but works out nice.
