ORIGINAL: saramos
. With the sim, I fly low so I don't loose orientation to the field.
Scott
On G-2, if you click on view and then click on look at ground, you can fly as high as you want to and still see the ground.
I'm not sure if this is the case with the newer versions of Real Flight.
