RCU Forums - View Single Post - q 40
Thread: q 40
Old 12-02-2007 | 12:06 PM
daven
Default RE: q 40
Or, just go to one of the bigger races and sort through the garbage cans at the end of the day. With some work, you could piece a fuse and tail feathers together, but you would most likely need to make your own foam wing.
The closest inexpensive similar planes are the Kangke SuperKraft F3D (which has been discontinued, but occasionaly show up on the Auction Site), there is an ARF called the LR-1, not sure if they are still available or not, but that may be option also.
