RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 12-02-2007 | 01:08 PM
  #1866
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
Yes, you can do it that way. They also make onboard glow drivers that run around $50.00 or less that can be programmed to come on at whatever throttle setting you like. If the cost doesn't bother you, that saves working out a mechanical switch arrangement.
You might also try your engine at first without on board glow power. Out of five airplanes I'm running on Gas/Glow, I only needed to put onboard glow power on one, and that was because I'm running a much too large carb on that particular application and the onboard glow allowed me to run a richer than normal low end to get a good transition.
AV8TOR
