RCU Forums - View Single Post - Restoring my Mach 1
Old 12-02-2007 | 07:03 PM
Vintage
Default RE: Restoring my Mach 1
I have never tried using plywood for a wing covering. I always thought it added too much weight. I have always used 3/32 balsa. The only glass and resin I used was around the center section of the wing. Most cases I monokoted straight to the balsa. If painting, any good filler and primer works fine before painting. I guess the plywood cut back on hanger rash.
