ORIGINAL: taven
First off thanks, I got a set from HeliHobby I think they are extreme core ???? I have both aluminum heads but had to remove the lower because the mod makes me use plastic. I balanced the upper head and shaft assy . And have checked that may times now. Tracking is well within flite standards. I even put my crash kit back on with no luck.
It is F*($EN crazzy out of control, maybe I will go back just to be sure nothing is wrong.
This thing is just starting lift off them it crashes to any side it might decide.
Not normal symptoms at all..... it never goes in the same direction. I am guessing maybe a servo got damaged somehow or is going bad. the CX2 I bought from my neighbor had a servo go out in 5 flights........although he wrecked it in everyone of those flights.
Another consideration is......... how well do the servo links connect to the swashplate? Is there a possibility you installed the links from the lower head to the swash upside down? (The long groove goes down towards the swashplate).
If helihobby is selling the repackaged Dynam Vortex parts like the canadian vender is I have heard of some incompatibility between parts.
Could you post a link to the upgrade parts you ordered and recieved? I know at least for me it will clarify what your issues are and a good place to start. It is fixable, and I bet you figure it out before we ever get a chance to exercise our "collective " minds.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
