RCU Forums - View Single Post - Beginner with new plane kit
Old 12-03-2007 | 06:29 AM
bkdavy's Avatar
bkdavy
Default RE: Beginner with new plane kit
For a first build with no help, FOLLOW THE DIRECTIONS PRECISELY! That means reading through the entire set of directions at least twice. Form a mental picture of exactly what you are going to do and when. When you've done that, read the directions again. Now you're ready to take the parts out of the box. Its very helpful to put all the parts in zip-lock bags, separated by section of the plane. Use a pencil to label EVERYTHING. Write lightly and it will sand off later.
As you progress through the build, keep track of the steps in the instruction book with a pencil mark. If the instructions don't already have a box next to the step, I make one when I read the step. Then I make an X when I complete the step. Keep every extra piece of wood in the kit. You never know when you'll need it. Even the small ends of the sticks come in handy.
Good luck. The LT-40 is a fine kit and an excellent flyer.
Brad
