RCU Forums - View Single Post - 2.4 GHz voltage protector?
Old 12-03-2007 | 12:06 PM
dubd's Avatar
dubd
Default RE: 2.4 GHz voltage protector?
2 batteries are not necessarily going to help you if you're pulling a lot of current. I've seen 30% 3D planes go down with Spektrum and they were powered with 2 lith-ion batteries. I *think* the solution is to ensure you're regulator can handle a high amp draw and you use deans connectors for the batteries. In all 3 cases, the guys were using standard connectors on the batteries.
