RE: Extreme Flight 110" 100cc Yak 54 Build!
Little progress tonight. Repaired the damage on the wing socket sheeting, checked the fuselage over inside and out. Looks like they used epoxy during the assembly in China. I hit a few places like where the vast plywood jigsaw puzzel of joints with thin CA, (Just me). All in all, I am very happy with the fuselage. It is very light, very strong in the right places, and very BIG. Mounted the motor and figured out that I need 50mm drop headers, measured from the surface of the exhaust port, to the center of the tuned pipe tunnel. I also laid out all of the gear that I am going to use, just to get a feell of how much room I need, of which there is plenty.
Jake, I am using a 5" CF 'Extra' Style Spinner from Troy Built Models.
