RE: Can't get off the water with Float Plane
add the spacer and if that doesn't work maybe you are a little under powered for your weight and you need to try the technique mentioned above.. that is if you have some experience bc you can mess up quickly if you over do it but like it was mentioned above lift one wing then the other, thats what the big guys do when they are underpowered on a glassy surface!
