RE: Need Help Please
I have it sorted at long last! I thought I'd write a response so at least people can see what the solution was this time.
I spoke to a technician at Spektrum last night and he has told me that reversing servos when using ccpm is not a good idea and I should be doing it by reversing the %mix for each servo.
So I set each servo to norm and reversed the aileron % mix, this didn't work at all. I eventually got it with everything working correctly apart from the role in the swash plate, the only way I could sort it was to reverse the pitch servo and all was perfect?
My settings are now -60% -60% 60% with the pitch servo reversed. I dont pretend to understand why this works but I would be interested in finding out. I did try to go -60% on the pitch as well but this did not reverse the servo.
All works now ok though, spun up last night and have tracking set and will set the pitch tonight and be ready for a maiden Belt-CP flight this evening! Can't wait.
Thanks for all your help crimsonrain22, shizack and bkind.
