RCU Forums - View Single Post - roll coupling????
Old 12-04-2007 | 08:32 PM
nmking09's Avatar
nmking09
My Feedback: (61)
Default RE: roll coupling????
or to the left,
if the plane rolls when rudder is applied, make a mix that has rudder as the master and aileron as the slave. The goal is for the radio to add the approperate aileron when you apply rudder so that the plane stays in knife edge. usually you mix right roll with left rudder, and vice versa. Start out with about 2 percent and then adjust from there
