You just get little gaps..
The strip in the center just gets the center of the rib (chordwise) level with the LE and TE sheeting...not a total capstrip, just enough to jump from LE to TE with the covering.
This just in!
I see the error of my ways!
The pics in Fig #17 & #19 show a servo-sized hole in the sheeting. I mounted mine like the ele/rud servos, thru a hole.
If I had a servo sized hole, I could get the servos out..duh!!
So if you build it per Fig 17 & 19, you will get them out.
I can't, but being an idiot that is my fault.
