RE: Blade CX folding blade big problems
Here are the pictures of the flybar link.
You need to shave one end flat so that the link has more free play.
The grips are much wider then the stock blades. It causes the link to hit it.
Make sure you adjust the length of the link so that it extends far enough to push the flybar up (opposite end down). Adjust the link till both ends of the flybar have about the same see-saw distance between it.
