RE: how r the pivot balls inserted inside the casing ?
well, first off what you have pictured there are not pivot balls, they are rod ends. in a rod end the inside part is just pressed into the outside part... a pivot ball is something else entirely... its the part on some car's/truck's that connects the upper and/or lower arms to the hub...
