RCU Forums - View Single Post - 2.4 GHz voltage protector?
Old 12-05-2007 | 08:30 AM
vasek's Avatar
vasek
Default RE: 2.4 GHz voltage protector?
Joe, you're right, the use of 6v for the 2.4 is probably the easiest prevention fix;
- do you use a regulator with the 6v packs?
- if yes can you post a link to it pls?
- did you come across any servos that don't like the 6v juice?
thanx,V.
ORIGINAL: joeflyer
Why doesn't everyone use 6 volt packs with 2.4G ? Seems like a better solution.
Joe
