RCU Forums - View Single Post - How to adjust saito valves
Old 12-05-2007 | 01:09 PM
bkrfrmhell
Default RE: How to adjust saito valves
Easiest way to set the valves with no chance of error is to rotate engine counterclockwise (running direction) until one valve is down, set the loose one. Rotate again under the one you just set is down, now set the other. Simple as that.
