RE: Hybrid Edge
After looking at the plans I'm thinking i would need the 50mm drop to get the can down in the fuse. Acording to Da the drop is measured from the center of the exaust to the center of the pipe.
I think Da has 4 different drops a 0, 25, 50, and 75mm.
Mike did you use the tuned pipe and header or was it the header and canister muffler? Da said ther is about a 50.00 dollar difference between the two. The tuned system being more. And can you remember the brand that would help in knowing which system was used?
Any body else use this setup?
