Prop Balance
So, what device do you folks use for balancing a prop? I'm reading about an entra coat of paint on the tip to achieve balance!! That sounds like an extremely sensitive device is in use.
Also, if you're not adding paint to a prop, how do you balance it? Sanding? If so, where?
I'll appreciate any information and advice.
Frank
