RE: 42cc engines?
Box car, do you know if any conversion parts will work on these engines that are built for other brands?
I don't know if it helps any but the pistons have 2 rings. Before I removed them from the scooters I checked the compression with the ease of the pull start and the one pictured had 125.5psi and the other 126psi. You can still see the crosshatch pattern on the cylinders.
