Twin-Ring Ryobi Bench Test Results
Volture;
I have a Ryobi, might be the one you are referring to. One or two flips and she starts every time. I was given a few pointers in starting these gassers. If you have access to your carb, stick your thumb or finger to block off the opening, make sure the ignition switch is OFF, and rock the prop back and forth at tdc. till you see some gas on the end of your finger, then give her a good flip. It might help.
