ORIGINAL: martinarcher
How hard is it to pull the rudder.
Very easy if you hinge it right. If you use Dubro heavy duty hinges and a piece of 0.047" music wire you can remove the rudder very easily. Simply remove the hinge wire and detach the pull-pull cables and it's off.
