RE: Engine compression
I dont think you will fine actual compression numbers on nitro engines. You will have to go by the signs of a weak engine like hard starting while hot, loss of power adn real easy to pull when cold. Usually if you can pull ont eh pull start and the truck lifts with it then you are good. If you have no resistance while pulling most likely its worn.
